Discuss Dangerous Situations Report in the UK Electrical Forum area at ElectriciansForums.net
I was looking through all the certificates on the napit site and noticed them..
Didn’t know they existed and thought they might be useful
Seem to be quite useful for me. Just looked through my cert software and I've issued 14 of them in the last 3.5 years.
Hi Charlie, they can be a useful tool. Like all certification is more about covering you're own back. A test cert of any description is like an insurance policy if filled out correctly.
If you have the need to fill out an Electrical Danger Notification you may also may need to isolate circuit ect. thus if the case an Electrical Isolation Certificate would be recommended to be attached especially if you are leaving the job.
Also useful if doing a first fix on an existing installation eg a kitchen refit where other trades / people are involved (who think they are electrically trained and switch on the eg socket circuit to put the kettle on and end up electrocuting someone).
I don't know of a certificate software that do one yet but I'm pushing for it. In the mean time I've produced a simple excel sheet which is set out similar to other well know certs. The basics follow similar to what I have filled out on some large site that I've worked on in the past.
Please find attached.
  • ISOLATION CERTIFICATE 2018blank2.pdf
get in touch with the local DNO call 105 you will only need post code and property name/number, explain situe, ie exposed conductive parts. They may say to get in touch with the meter operator, if you have info then ok, if you don't then push for them to sort, they normally come out within the hour. from experience most DNOs throughout the UK are pretty good at this now. Don't leave for the customer to sort as they don't normally from experience. It is part of your duty of care, to ensure left safe or dealt with. If it goes pear shaped, it will be you being dragged through the courts. You are the "competent person" not the customer!!
Its a void property, the owner is the council. Standard procedure for them.
Last time i called the DNO on something like this, they told me the meter wasnt anything to do with them and to call the energy supplier, which noone knew who they were at the time.
www.hollycroftsoftware.co.uk do one. I have used Hollycroft for many years and are brilliant!
Hi @Top Cat just had a quick check on hollycroft couldn't find a Electrical Isolation Certificate, though could find the Dangerous.
How do you find there calculators for cable sizes ect, been trying to find a sensible priced one for years. Cheers
Have only used it a few times but it seems really good. If you do get it go through it a few times practising as the first time I kept forgetting to put in some parameters!
Considering what you get in the package I think its really good value for money. The other thing is that it is a father and son business so one phone call or email and they usually get back to you within the hour.
Reply to Dangerous Situations Report in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
I have an inground pool with a 22 year old, 120vac light fixture in a niche connected to water-holding conduit running to a switch in an...
you have discovered a water pipe in a bathroom that has been repaired at some previous time using a plastic connector. please help, thank you.
Has anybody got an opinion on the book called ELECTRIC MOTOR MAINTENANCE AND TROUBLESHOOTING. There is on one ebay and the isbn is 0071763953...
They are going off and back on but not tripping at the fuse box. Could anybody tell me what could be the cause and if this is dangerous? Thanks
