- Reaction score
- 315
Evening and happy Friday!
Does anyone regularly use or know of a suitable way to relocate a DB from its original position (adjacent to main fuse) if there is nowhere within 3m of the main fuse inside the building where a fused isolator can be fitted?
Main fuse is in an external meter cabinet, current DB position is on the other side of the wall, new DB position is to be 10+ metres away.
Is there a surface mounted external box which can be fitted in which a fused isolator can be installed inside?
Is there another way of fitting it internally which is still acceptable?
Thanks.
Thanks.
