Dd0
Discuss Dd0 in the UK Electrical Forum area at ElectriciansForums.net
Dd0 delta input delta output 0 degreee phase shift as its delta output there will be no neutral. sorry not been of much use studied trannys a long time ago
Reply to Dd0 in the UK Electrical Forum area at ElectriciansForums.net
Hi Changing a 3 phase star delta motor and replacing with a dol 3 phase motor. Would i be right in thinking I can remove 3 of the 6 cables at...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Having a challenge understanding the concept behind why when you measure across line and neutral (live circuit) using voltage indicators we have...
