Discuss Dedicated line for outbuilding? in the DIY Electrical Advice area at ElectriciansForums.net
mjc1925
Looking to replace a damaged underground cable feeding a small outbuilding. Is a dedicated line from the panel required ?
Current setup when I purchased the house: The cable feeding the outbuilding (about 10 feet from the house) shares a circuit with a ceiling fan and two lights in the house. The outbuilding now has two outlets and two lights on pull chains.
If a dedicated line is the way to go, there's no room in my panel for a new breaker. There is an outlet coming off the panel with nothing else on the circuit. Could I use that to extend a new line?
I would change the duplex outlet on the unused circuit to GFI then use that to run to the outbuilding. That way you would be protected from being electrocuted from an outside line.
Reply to Dedicated line for outbuilding? in the DIY Electrical Advice area at ElectriciansForums.net
I have an outbuilding a fair distance from the house. In this outbuilding I just want to have some lights, a small music radio/clock, and a...
Last year we purchased a home that was built in the late 1990s It has one outbuilding, sort of a barn/shed about 160 feet from the house (and...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
