Discuss Degreaser in electronics in the Auto Electrician Forum area at ElectriciansForums.net
Evening all
When fixing the broken air intake pipe on a 2013 Qashqai I decided to degrease the oil and dirt from the engine.
Looks like I was a bit too generous applying it and has found its way into the electronics. Several strange things are now happening.
The odb port doesn't connect.
The tripometer/mpg resets to zero every time its started.
The hands on the speedo shake for several seconds on start up.
Does this point to a specific connection?
Would removing them and using contact cleaner help
Leigh
Would be worth disconnecting the battery then unplugging the ECU/S and blowing the terminal blocks out with an airline being careful not to blow directly onto any weatherproofing on the ECU.
Also a hard reset wouldn't go amiss, however I'm not familiar with the specifics of the Qashqai so I can't say how to do it.
Reply to Degreaser in electronics in the Auto Electrician Forum area at ElectriciansForums.net
