Discuss diamond core drill bit for 4 inch fan holes in the Electrical Tools and Products area at ElectriciansForums.net
I've got the set that Makita do. I've battered it and it just keeps going. A bit more expensive than some of the others but well worth it.
I would go with 107mm as well. The cheap ones don't last long (but do work while they are OK).
Core bits tend to strain SDS drills, if you are building up start with using the SDS but consider a core drill when you can. (I haven't got one yet but have had to buy a new SDS!)
If you're going to connect the outside grille with solid duct, then you can use 107mm. The duct will be a snug fit in the hole and as mentioned above there's more brick left for fixings.
If you're going to connect the grille with flexi tubing then you will need 117mm as the flexi won't fit through 107.
I use Norton bits which I get from Screwfix.
Make sure you are using a drill with a clutch release or you're likely to break your wrists off. I use a Bosch Pro DRE-26.
It will if you twist it, put your hand inside it and gradually inch it forward grazing your knuckles while cursing the bl**dy thing and trying to stop it tearing! Apart from that. piece of p**.:wink_smile:
Todays lesson ....speaking from experience, i guess, LOL. My wrist still aches from trying that about 2 years back. lesson learnt after about the fifth time.
Make sure you are using a drill with a clutch release or you're likely to break your wrists off. I use a Bosch Pro DRE-26.[/QUOTE]
Further to this:
If you adhere the grille and tube together using conduit cement, you can drop a plumb line out of your hole and lift the grille/tube assembly up to the hole from the inside. Reach out through the hole and pull the tube through. Rotate to align the grille outside (or use a round one). Now fill round the tube with Stixall or similar. Voila, grille in place and no need for a ladder!
Thanks... i'm going to be using my sds drill for the time being as i've just brought a new van so moneys rather tight. think i'm going to get a 117mm one.
Reply to diamond core drill bit for 4 inch fan holes in the Electrical Tools and Products area at ElectriciansForums.net
So today I was coring a 6 inch hole for a kitchen fan, now I cut my hole in the kitchen plasterboard and used a long sds bit to drill out the way...
This isn't very electrical, but never mind! I'm adding an extractor fan to a bathroom in a 4th floor flat. The builder has helpfully cored a hole...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I need to drill holes in the tile wall for some household tasks. Therefore, I want to know exactly what type of drill bit will suit best our...
