Discuss Different Cable Size in the Canada area at ElectriciansForums.net
T
truth
Hi
Can we use existing 2core x 70mm2 and 2 core 50mm2 (850m length) cables to carry a 3 phase supply (3 phase and neutral).
Load : 5KW
Purpose : to feed the UPS unit
Concerns would be from the voltage drop and the terminal voltage difference at the end point. I have worked out the voltage. They are within the limit.
The reusage of the existing cables will save enormous money (cables, trenches).
No Nearest secure power supply is available. Either to run a new cable or reuse the existing cables.
Could You advise Your opinion please.
Reply to Different Cable Size in the Canada area at ElectriciansForums.net
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
