Discuss Dimmable Driver With 240v Output!!! in the Lighting Forum area at ElectriciansForums.net
I think you're going to need to be a bit more specific.
From a brief Google, I've established that there are high frequency ballasts (for fluorescent tubes) that can be dimmed using a 1-10v signal. There are also LED drivers that can do the same.
Are you after a dimmer for say normal halogen lamps that can accept a 1-10v control voltage?
Yeah exactly that.
Reply to Dimmable Driver With 240v Output!!! in the Lighting Forum area at ElectriciansForums.net
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
Hi everyone I’m after some advice please. I’m installing some LED profile around a customers bedroom ceiling for some led strip to sit in and...
Hi everyone, I have a basic knowledge of electric but would like advice before I attempt, I have a electrical item that is powered by Voltage...
Hi, DIY’er here. I need a replacement transformer but can’t find the exact model required anywhere. It is Golden Power GP-SW120DC0700(UK)...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
