Discuss Dimmer switch advise please in the Lighting Forum area at ElectriciansForums.net
Hello all,
I have just had 2x LED down-lighters (ENLITE DE8CX Dimmable, IP65, 8W, integrated LED Fire rated) (from Screwfix) installed, using 1x normal rocker type on/off switch to control both but want to change the switch to a dimmer type. Can you please advise type (preferably Screwfix but not only)
Also can you advise type of dimmer switch for 1x normal 60w ceiling light.
best regards.
I'd just be careful with dimmers since I've found them to be a nightmare with LED lights, customers complaining of buzzing . But varilight do a range that I like called varilight v-pro because they seem to have less problems than the others.
When I looked enlite website they have a dimming chart and one of their recommended dimmers is varilight but I don't know if screwfix do it.
Heres the chart: Dimming Compatibility. Enlite - Lighting Essentials - http://enlitelighting.com/gb/dimming-compatibility
Click the E8 tab at the top of the webpage and it has list of compatible dimmers.
Reply to Dimmer switch advise please in the Lighting Forum area at ElectriciansForums.net
