Hello, first time poster, be gentle please...
I have a torch LED light with two lights, one spot light and the other is really a torch light. As shown in the image below, the switch is between two, six feet steel pipies, about halfway up, ordown dpending on the perspective.
The switch for the latter one broke and stopped working; The actual switch is:
The power supply is a tranformer, 110VAC to 36VDC.
I've been trying to find the original switch, or similar rotary dimmer, but no luck. The 36VDC seems to be an odd voltage, at least in the US..
Can anyone recommend a replacement switch for this application?
At this point, two single switches with 16VDC would work as well, after modifying the mounting plates.
TIA...
TIA...
