Discuss Dimmer switch issue in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I have an issue with my bathroom dimmer switch. The issue is that there is a humming/buzzing noise coming from one of the lights. Even after replacing the lightbulb several times and removing it completely - when the dimmer switch is turned as far right as possible, the buzzing starts again. This must be a problem with the dimmer switch? Or is that an electrical fault?
Any advice would be great.
Thanks!
Do you have a fan in your bathroom too? Are they they low voltage lights? Working out what is making the noise is step one and I’m wondering if it’s a transformer or a fan.
Reply to Dimmer switch issue in the UK Electrical Forum area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
My daughter is asking me if it’s possible to change her double light switch outside her bathroom to a dimmer. It’s a 2 gang switch that turns on...
Hi, Just looking for some advice. In a bedroom there are 5 downlights on a dimmer switch. When turned on, every now and again these lights can...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
