Discuss Dimmer switch wont fit! in the Industrial Electricians' Talk area at ElectriciansForums.net
a few pence will buy you a frame which sits behind the switch and lifts it off the wall about 6 or 7 mm so any dimmer will fit into a shallow box. You will probably have to use longer screws and maybe re-thread the lugs in the box. I used to chop new boxes in until i found these. I know CEF stock them and they save a lot of hassle and don't look unsightly either.
You can get a remote dimmer that will fit, loads of places sell them. About 50 quid for a nice chrome/plat/satin. I love em, 10mins fit
Although depth of box is an issue with the actual fitting of the dimmer, it is also recommended due to heat build up.
This is why you can only get most 2 gang dimmers rated at 250w a side.
Reply to Dimmer switch wont fit! in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
Hi there, I am looking at specifying a Triac dimmer switch after a PIR and manual override to control several lights, i dont see an issue why...
