SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Discuss Dimmers and LEDS...!!!! in the Electrical Forum area at ElectriciansForums.net
yesterday was working in a house where a different sparky had installed LED spotlights on dimmer switches. the leds flicker when you dim them. also the mcb the lights are on buzzes when the LEDs are on - to do with harmonics I think. But the funny thing is I know another house that was done by the same sparky with the exact same problems. Why would he keep doing that - surely he would have learnt?? and is it only certain combinations of dimmers and LEDs that flicker because I constantly install LEDs on dimmers but they never flicker?
  • #3
maybe... but what do you suggest he does to change it?? different dimmer switches?? i think he uses bg nexus ones - has anyone had any problems with them? is it to do with the wattage rating of the dimmer?
Charlie_
Compatibility issues..
Standard 240v LED fittings are best dimmed using trailing edge dimmers..
Don’t want to get too technical..
Zano and varilight are the most readily compatible
You should do some research, the manufacturers have compatibility charts.. Have a look at them, sorry tell your friend to have a look ;)
Charlie_
If you try to use traditional type dimmers with LEDs you will overheat then and cause damage to them and associated equipment on the circuit
+1 for Zano never had a issue with them fitted to various led loads.
I once fitted a BELL dimmer module did loads of research, on paper it was 100% compatible. 10 seconds it was in and it started to smoke and melted.
  • #7
yes i understand your point. i have noticed zano before. its all to do with the copper coil inside a traditional dimmer I think. will let him know :)
Charlie_
The coil in traditional dimmers is there to absorb spikes caused by the triac switching on and off at the peak.
A triac is basically just an electronic on off switch..
Remember as a child when you would hold a switch till the light flickered din,
that’s basically what the old dimmer switches do
DPG
Advent Win
Lovely analogy for phase angle control.
Mind you, I know what you originally put that post . Only kidding.
Tony Reidy
What dimmers do you use
Charlie_
Thank you, I like to put things in layman terms and use analogies where possible, whenever I get too technical I’m usually confronted with a blank face
uHeat Banner - Forum Discount Available
Reply to Dimmers and LEDS...!!!! in the Electrical Forum area at ElectriciansForums.net
Aico Carbon Monoxide Detectors
Top Bottom
