Discuss Dimming an Outside LED Light? in the Lighting Forum area at ElectriciansForums.net
Hi guys,
I am looking at having a outside light installed over a door, the light I am looking at uses a E27 bulb fitment which I am planning to use a LED replacement.
I would like to be able to switch the light between two brightness levels using a PIR so the light is on a lower brightness level all the time only to be switched to 'full brightness' when the PIR detects movement.
What would be the best method to do this?
Just stick a dusk till dawn led bulb into the fitting...no need for two light levels imho. Burglars don’t give a Minnie’s about flood lights as they get ignored by everyone and will go out. They hate constant light at a reasonable level though.
my floodlightscome on for 2 minutes. time enough for the scroat to find his way to the back of the house.not enough to see the 240V trip wire next to the pond.
Reply to Dimming an Outside LED Light? in the Lighting Forum area at ElectriciansForums.net
I have two 4 inch recessed CLF 4 pin light cans installed in laundry room since 2012. The bulbs are fluctuating in brightness. I think the...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
I want to buy two of the above for my property. I am on a budget. The property can get battered by driving rain, finding an outdoor LED flood...
