Discuss dimming led's in the Electrical Forum area at ElectriciansForums.net
The V-Pro dimmer linked will dim Inceptor max very well, not tried on the micro but no reason to assume it won't.
I'll be surprised if you can find any dimmer that will dim one of those LED filament lamps. I haven't yet, although I've not tried for a few months.
Hamilton for the last maybe? I had to try different makes of that type of lamp to get it to work with it though a few months back. Led + dimmer = problems
You would need to get a dimmable version of the LED filament bulb in order to be able to dim it, then I would expect that the V-pro might be able to dim that lamp but it would be below the minimum wattage of 10W, so a resload or such like might be required to up the load slightly.
Should work OK on 6 of the inceptor micro.
bright - 620 lumen - and dimmable to <1% using a conventional dimmer
should be OK i guess?
Reply to dimming led's in the Electrical Forum area at ElectriciansForums.net
