Discuss Dimming low voltage lights? in the Lighting Forum area at ElectriciansForums.net
You'll have to establish if the LED driver is dimmable or not. If it is the manufacturer might specify if that dimmer is compatible with their product.
LED driver ? I thought this was just a simple adapter that converted 230v to 12v,
I'm not an electrician but common sense made me wonder if changing the switch to a dimmer might put strain on the adaptor when at 50%.
Try it and see, from the pictures it looks like that dimmer will just plug in after the switch. It will be nothing more technical than a variable resistor which you connect in series with the lights.
Due to the nature of leds you won't get a full range of dimming but it will work within certain limits.
That dimmer plugs in after the driver in this case so the driver doesn't need to be dimmable, it will just be a variable resistor altering the voltage across the leds.
Fair point, but the LED lamps may not like being dimmed, i.e. they will either dim or not.
Where do you plan to plug it in?
I thought LEDS respected whatever voltage you threw at them.
I thought LEDS respected whatever voltage you threw at thems.
I don't understand how they work, nor do I want to. But with experience installing LED luminaires, dimming them is somewhat of a dark art
Always best to check with the manufacture, to see if their product can be dimmed, and what would be a suitable compatible dimmer.
You could strike lucky, but you stand the chance of wasting time & money. But I suppose in your case there's not too much to lose, so worth a shot.
Reply to Dimming low voltage lights? in the Lighting Forum area at ElectriciansForums.net
