Discuss Dimming in the UK Electrical Forum area at ElectriciansForums.net
Mark.W
Hi chaps,
Does anyone know if it is possible to use a daylight dimming sensor on a basic switch dim config or does it need to be DALI?
I've recently taken over a job from another spark, and the spec states to incorporate daylight sensing as well as manual dimming via a retractive switch into the circuit but the system has been wired with a dimming pair ie switch dim and fitted with Hager Klik boxes??
I thought it would need to have a control ie DALI??
Any help would be appreciated.
Regards
Mark
What Hager klick boxes have you got the 6 pin ones ?more info needed are you sure about the switch dim it is most likely DALI DIM pir's with retractive switches
Reply to Dimming in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
THHN is supposed to be enclosed in conduit when behind drywall. Romex does not have the same requirement. Romex is "basically" THHN encased by a...
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
