- Reaction score
- 1,345
Fused spur off ring with 13a fuse supplying 4x 3-gang fused socket outlets for a small computer area. Loads not going to be massive. Should the 4x 13a fuses in the 3-gang sockets be changed for a lower rating, e.g. 10a, to allow for discrimination between sockets outlets and the fuse in the FCU?
In theory I think yes, but then again how often are multiple fuses used, e.g. when we use a power tool plugged into an extension flex. But then again, I'm talking about fixed wiring, so it's a different situation.
