Discuss Distribution circuit to Sub Main in the Canada area at ElectriciansForums.net
M
mercanlandy
Hi, I need to know what info I should enter on the periodic inspection report in regard to the distribution circuit. The form requests the size of the phase conductor and the cpc". The distribution circuit is a 4 core SWA and the armoring is used as the cpc. What should you enter as the CSA" of the cpc. The measured Ze at the sub main was 0.14 ohms.
All help appreciated.
regards
SC
regards
SC
Might be helpful.
Swa armour csa's are listed.
http://uk.msnusers.com/SparkyHeaven/Documents/General%20Technical%20Information/SWA%20and%20Earthingby%20John%20Peckham%20version%20Jul06.pdf
PS it's not my work the credit must go elsewhere.
I have seen PIR's where under CPC on a SWA circuit they have just written SWA.
To be honest if you use 2.5mm SWA (for example) then the CPC (armour) is always goona be pretty muchn the same
Reply to Distribution circuit to Sub Main in the Canada area at ElectriciansForums.net
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
