B
brman
Just pondering my voltage drop calcs for a fused spur off a ring final. Additional circuit will be around 15-20m long so I though I should do this properly....
My problem is calculating the voltage drop in the existing ring to the point of the spur which of course depends on distribution of load round the ring. I've seen two methods used-
1) 20A at the furthest point and 6A distributed evenly around both sides of the ring. Giving the equivalent of 13A average either side or 26A at the furthest point.
2) 32A distributed evening around the ring. Giving an average or 8A each side or 16A at the furthest point.
I did look at the ESC essential guide on this but it just shows how to calculated it if the actual distribution is known which I can't see working with a socket ring where future use is not known.
What would you guys use?
