Discuss DNO specifies fire-rated enclosure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
knxhome
The DNO (UK Power Networks) has specified that the duct that will carry the DNO supply to a new SFH has to terminate into a 1-hour fire-rated cupboard.
The duct will terminate in the basement, and the supply will be 3P 100A each.
Which pre-made cupboards would meet the required specs, or if we want to build our own cupboard how would we achieve the required fire-rating? An industrial steel enclosure is not permitted by the DNO.
The cupboard may be mounted either directly onto a concrete wall, or onto a concrete wall that has some internal thermal insulation.
I assume they are talking about the normally white utility meter boxes you find surface mounted or sunk into most new domestic properties... they are of a fibre glass construct i think so would assume have a fire rating to suit your needs but enquire with supplier.
Speak with the DNO they may be mistaken as to the mounting position they may think your fitting an external enclosure as found in most newbuilds ive not heard a requirement to house the cutout and meter in a fire proof enclosure if its internal in the basement?
A cupboard should also suffice boarded with fireboard.
The DNO inspector has seen the building-in-progress and is aware of the internal location of the meter box.
Its a new one on me ... may be a regional thing or new requirements - i mean how many cutouts are just screwed to a wall ... i would have a joiner build a cupboard with 1hr fire rating and confirm with DNO if this will suffice and will it require any specific door latch or lock.
If this is a commercial supply then they insist on it being in a fire rated enclosure / room. We normally get a stud wall built around it then a door with intumescent strips etc pretty easy.
Fibreglass meter boxes are not fire rated and give off toxic fumes when exposed to flame. DNO will not allow them to be fitted internally in my area (WPD)
Thanks, very helpful.
In light of all the advise given here we will go will with a home-made cupboard out of fire-rated material with a door with intumescent strips.
Reply to DNO specifies fire-rated enclosure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
  • Locked
5K
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
Hi all, After some thoughts on the following scenario. Block of 16 flats configured 4per floor over 4floors - on each floor is an electrical...
14K
Hi I am a sparks from the 15th Ed, did 16, 17 and last year 18th. I am out of practice though as have been office based for 12+ years in a...
  • Locked
Hi, we need some advice on our scenario with regards to our rewire plan. I will get this out of the way first... We are planning to put the house...
5K
