Discuss Do AC powered wireless thermostats exist in the Central Heating Systems area at ElectriciansForums.net
Hi,
Does anyone know of a wireless thermostat which can be mains powered rather than batteries? We have very difficult cable routes for the control cables but easy AC supply. It seems a shame to hang the system on batteries if the stats could be main supplied.
Thanks in advance.
give Alan Sugar or Dyson a half hour.they'll come up witha design that fails 2 weeks after the warranty is up.
I can't see any on the market, which is a little surprising.
If you used a wifi cylinder stat that took AA or triple A batteries, how about one of these horrible things: View: https://www.amazon.co.uk/UK-Christmas-World-Battery-Eliminator/dp/B01M4RUNZR/ref=sr_1_3?dchild=1&keywords=3v+Two+aa+battery+mains+adapter&qid=1601918775&s=electronics&sr=1-3
Would it last longer than the batteries?
I wouldn't trust that to work on power up, let alone longer than some good batteries!!
nest will do that
Maybe I misunderstood the thread, I thought the question was about finding a mains powered Wifi cylinder stat to send stored water temperature to a system controller, or to switch the boiler. I don't think Nest has a way of measuring cylinder temperature, it can use Opentherm comms, but that doesn't give exact cylinder temperature surely?
Please tell me if I'm wrong.
I know Nest Gen 3 allows you to power up remote until using USB, it is basically a battery eliminator, and in real terms you can fit a battery eliminator to any thermostat. But if I look at my own system, the Nest Gen 3 is hard wired with a 12 volt DC supply to thermostat, but still have 18 AA batteries to work the system, 2 in each TRV head, so what is the point doing the wall thermostat with mains supply when you still have so many batteries to run the TRV heads.
Reply to Do AC powered wireless thermostats exist in the Central Heating Systems area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi there, We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
Hello, I'm in the process of changing my wired remeha thermostat with the wireless hive mini, I've had a look at the manual and believe I have...
I recently fitted a Heatmiser Neostat for a customer in their hall- to control their radiators throughout the house (70’s 4 bed medium sized...
Hello I have a central heating system, with a Y plan layout. The neon indicator on the thermostat seems to be sometimes dimly lit / flickering...
