Discuss Do I Have To Have A Proving Unit ?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
TPES
Juts a quick question
Do you HAVE to have a proving unit for you NIC Or Elecsa assessment ??
Will I be expected to have one?
Hi Magic-sid
No just most people use them but you need to prove on a known supply ie cu incomming then main switch outgoing then back to cu incomming etc
Regards
Kung.
Prove unit test circuit is dead then prove unit again doesnt matter if on proving unit or known supply as long as you do it !
Thats ok then, a friend of mine had his NIC yearly visit and he had to use his proving unit.. maybe he was just a one off!
I wont bother buying one then... They aint cheap either for what they are.. esspecially when there not needed!
Only thing they do is prove tester is working doesnt prove if there is a power cut thats why i use supply to prove unit and if tester doesnt work i resort to my test lamp.
He would be required to prove tester working but its not a requirement to use a proving unit supply will do.
Regards
Kung.
had my nic visit last week no prooving unit required was happy with volt meter martindale type with the lights alongside values but he did comment he dident like using multi meter as meter could be set to wrong setting
hi there
not to mean any offense
why would NOT have one surely it is better to prove the tester before and after use it is just plain common sense to make sure it is dead before commencing work ?? :)
cheers
Prove tester on proving unit or KNOWN SUPPLY ! doesnt have to have one just prove one way or other at the price they are its a rip off and just because they prove tester is working they dont prove there isnt a power cut thats why i test incomming to main switch then out going then incomming (prove tester prove dead prove tester)
hi there
you have a pint but the humble volt stick can help in the power cut aspect as a guidance of course no way would i rly on a volt stick to prove dead :eek:
cheers
:D
nor would i thats why i always double check with my test lamp when i was at southern electric we had loads of faulty volt sticks mine you had to flick now and then ! some prof lol
hi kung, nic man liked to see proving unit at my recent assessment ;)
just out of interest how would you prove your tester in the power cut scenario when you havent got a known source :confused:
still a very handy bit of kit for the toolbox ;)
Hi Flukey
I would turn main switch back on and try lights etc but yes the proving unit is handy just think their well overpriced for what they are unless you can get a cheap one. my voltage tester has a self test function as well its a steinel combi check german made rated upto 660v ac/dc with that and voltstick and multimeter and test lamp etc i could prove power cut as well as the turn main switch on and check lights etc
Regards
Kung.
I do however have a proving unit for my test lamp.
Reply to Do I Have To Have A Proving Unit ?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
i need to purchase a voltage proving unit - i have seen Megger MPU690, Martindale PD690, and Socket and See SP400, and Fluke but difficult to...
Today I went to fix a minor loose screw on something and after switching off, etc, got out my Martindale VT12 continuity & voltage tester and...
At the work place. When proving an 11KV Transformer is Dead. We have HV test sticks. With a function test. Part of the procedure is to function...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
I've booked in an electrician to run an EICR, I have an old unit here, whilst searching for quotes one guy said it looks ok and may not need...
