Discuss do i need 2330 level 3, if i have 2391 and 17th Edition? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
mist
Hi, for LUL works, do I need have "2330 safe isolation level 3" separately if I already possess 2391 Insp. & Test. and 17th Edition ?
Thanks for any help.
Peter.
safe isolation level 3? if you dont have your c&g 2330 lev 2 and 3 why did they let you on the courses my college tutors wouldnt let anyone sit the 2391 untill after they completed 2330
With regards to competence in safe isolation procedures, the 2391-10 should be considered acceptable as it is the same syllabus than the 2330 equivalent.
However LUL may have requirements about what is and is not a competent person for undergoing electrical work.
If you are doing electrical installation work then they may not consider you competent as they may not recognise you as a competent electrician. Whilst if the scope of the work is in testing and inspection, then the 2391 will most likely be considered as competence for that work.
there are no qualifications required to do 2391, however a "practicing electrician with a good understanding of BS7671" is recommended, one of the instructors round my way could recall a maintenance fitter, who against all advice and no 16th edition, enrolled and passed 2391, not the norm though.
Reply to do i need 2330 level 3, if i have 2391 and 17th Edition? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
JIB Electrotechnical Certification Scheme (ECS) is a nvq3 and am2 all i need?
Evening all! im looking at progressing and trying to obtain a JIB gold card but unsure what i need altogher. i currently have C&g 2330 level 2...
Hi all, I completed my level 2 2365 installation and my level 3 8202 advanced technical diploma in electrical installation and I’m unsure on...
Hello all Planning to do the 18th edition online. I could just batter loads of old papers on the head and then have an attempt ( I will do loads...
Does anyone else get emails and phone calls from companies and agencies say we seen your CV and we want you to apply for our job. And when you...
