Discuss do I need to test my equipment?? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
M
mattcpc
Hi all
I run an AV department and have alot of electrical equipment none of it is used by customers or the general public and it sits in situi. i'm not sure if they need testing and gov web sites arent much help. hope someone can help.
cheers
matt
Hi, if any of the items are used by any member of the business for any purpose on the business premises, then they fall within the scope of the H & S regs which insist on them being maintained in such a manner that risk to users is eliminated.Obviously , how you do that is up to you, but PA testing is probably the most cost effective way.
Legally you just need to ensure that you have a maintenance program in place which could involve a full test or just a visual inspection although your insurance company may stipulate that you should have them tested periodically with a certificate on hand. I'd check with the insurance company first just to make sure.
Reply to do I need to test my equipment?? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Morning all, We are looking at qualification requirements for inspection and testing to BS EN 60204, all of our work is past the main isolator of...
Hi Hope anyone can help Can someone give me advice on how to connect up a 3 phase to 13amp adaptor lead for carrying out PAT testing on 3...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
