Discuss Do I need to upgrade my service panel? in the UK Electrical Forum area at ElectriciansForums.net
Hey all, I've got a question about a new apartment I'm getting. I recently had a home inspection done on it and the inspector noted that my panel was double tapped and drawing what might be a little too much power for its rated size.
The apartment is a 700 sqft one bedroom and all appliances are electric (heating, range, hot water, AC, etc...). My question is, what is the normal amperage rating for an apartment like that? My service panel is currently 100 amps which I thought would be enough, but given that all the appliances are electric and some of the breakers are double tapped my inspector mentioned I might want to get a service upgrade done on it. Units are wired individually so upgrading would be mine/the sellers responsibility and would run up about 2500-5000. Do I need to get it done or am I just being overly cautious?
I attached some of the pictures from the inspection report.
Hopefully one of the USA folk like @Megawatt can comment, as the power usage is likely very different from UK norms (and we have 230V supply so current is about half compared to 120V).
In all cases you should look at getting a couple of quotes from reputable electricians, also discuss what you want longer term and see who appears to tick all of your boxes. Don't automatically go with the cheapest, and don't assume the first opinion is going to automatically be honest/in your interest either! But they might well be.
Hebert welcome to the forum and yes it needs an upgrade. The biggest problem is that you don’t have enough spaces for all your loads. It needs to be changed to a 200 amp main panel and yes for a service upgrade it normally cost around $ 2000.00-$ 2500.00. Your not going to overload the 100 amp panel but you are not allowed to have more than 1 wire per breaker. Good luck with your panel and please make sure it’s a licensed electrician doing the work.
Reply to Do I need to upgrade my service panel? in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
Hello, I am a homeowner and have a solar project coming up. I intend to install a 9kw solar system but I am not sure if I have to upgrade my main...
Our farm has a main 200 amp panel in the barn which services the barn, an addition to the barn with an apartment, an herb-gardening facility, and...
