Discuss Do LED lights require specific wiring? in the Lighting Forum area at ElectriciansForums.net
Scotty
Just changed my outside light (100w bulb) with a security light with PIR fitted with a 1.5w integrated LED light and a 5w LED candle bulb. Can't get the new light to work. There is nothing wrong with the new light as I got it to work with a 3 pin plug. Any ideas anyone?
Hi - theres no special wiring needed, just a circuit with L and N as you had before. Is it possible that something has been disturbed (and a connection broken) during the change - perhaps post up a pic?
Sorry to state the obvious, but have you checked the light switch is on, and all the MCBs and rcd’s at the board are on?
If there’s an rcd, it can trip if you touch neutral, even with the circuit mcb isolated.
Hi Wilko. I will try and elaborate a bit more. There are 2, 2 gang switches in my hallway. Lets call them mirror and window switches. The left hand switch on the mirror is for the 2 way upstairs lights and the right hand switch is for the 2 way downstairs lights. The left hand switch on the window is for the outside light I'm having trouble with, and the right hand switch is for the 2 way downstairs. Prior to changing the o/s light I realised years ago that the o/s light would only work when the 2 way switches for the downstairs lights had to be in a certain position, hence my original question. Don't know if it has always been like this from when the house was built in 1978, or whether the o/s light was fitted by a previous owner. Obviously the wiring is not quite right but would work with the original o/s light. I didn't open the window switch so nothing should be disturbed in there. Hope that makes sense.
Hi Littlespark, I always isolate on the board when I'm doing something like this. Please see my follow up to Wilko. It might shed some light on the subject, excuse the pun.
sounds like the outside light is fed from a switched live instead of a permanent live. should be a 20 minutejob for a spark to sortout. provided the existing wiring can supply the necessary.
Thanks Telectrix, I tried all the configurations on the downstairs 2 way switches hoping I would get the right one but no joy. Would the switched live stop it from working or should I have got it to work with the right config?
I might have to get a spark out. Hope it is as easy as you say.
you may be unlucky and find that the permanent L is at the wrong switch.
As Wilko said, post pics of the wiring at both switches so we can get an idea of what's what.
Hi all,
Thanks for all the advice and help. Wired up the old light via an extended 3 core wire and it lit ok. Noted the 2 way switches for the downstairs light had to both be in the off position, ( switched live as telectrix says). Not a problem as I can put up with that. Wired up the new light via the extended 3 core wire and it lit ok. Wired it up in its permanent position and all OK. As Wilko said, possibly a bad or broken connection. Cheers all, will keep you in mind the next time I cock it up.
Reply to Do LED lights require specific wiring? in the Lighting Forum area at ElectriciansForums.net
Hi all, H.N.Y. The passive, affixed to a recently bought LED security light is rubbish, sometimes it works, mostly it doesn't, no matter how...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I've just changed the bulb in an outdoor PIR security floodlight (to LED). But the light stays on by default, and turns off when I go outside. I...
