Discuss Do Siemens make a 50/50 Quad Circuit Breaker? in the UK Electrical Forum area at ElectriciansForums.net
csned1
I have a newer all electric manufactured home with a Siemens 200 amp service panel. I'd like to replace my standard water heater with a 24Kw tankless water heater that requires two 50 amp 240v double pole breakers. I only have two side-by-side regular slots available in the panel. Does Siemens make a 50/50 Quad Circuit Breaker that will fit in the two slots?
Yes I’m sure they do. What style panel like an QO panel do you have. I’m sure that you can buy the slim line breakers and install them to free up enough space for your tankless hot water heater. Go to your local electrical parts house.
Thanks for your reply. Unfortunately, when I didn't get a reply after a couple of days I went ahead and went with another standard water heater.
Reply to Do Siemens make a 50/50 Quad Circuit Breaker? in the UK Electrical Forum area at ElectriciansForums.net
Trying to connect a 50 amp inlet box to my Siemens outdoor combination panel 200 amp cutoffs. Can’t figure out where to insert the 50 amp breaker...
4K
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
