Discuss Do you need cross bonding in the Electrical Forum area at ElectriciansForums.net
littlespark
Main bonding is to the supply pipes.
Equipotential bonding is between copper pipes at a bath etc.
So the answer is no.
Check the gas isn’t copper pipe inside a plastic coating. (Yellow)
Reply to Do you need cross bonding in the Electrical Forum area at ElectriciansForums.net
Kitchen in Care home. All metal surfaces. No bonding and no earth on test. RCBOs in DB. Does this still need bonding????
Did a eicr on a upstairs flat, there is 1 main bonding cable from the consumer unit, the gas pipe comes from the gas meter outside and up the wall...
This is a question (or discussion probably) regarding selecting the main earthing conductor, and subsequently the main equipotential bonding...
hi there as i write this i realise i have 3 interconnected questions about fused switches; two relating to my boiler (hope its not to cheeky to...
My parents and my oven both need new oven lamps but both mine and their glass lamp covers are completely stuck / cross threaded and won't come...
New Posts (Please Reply)
