uHeat Banner - Forum Discount Available
Discuss Documenting new circuits in existing board in the Electrical Forum area at ElectriciansForums.net
Sean McD
Evening all. So got a job coming up; adding new circuit to exsiting DB. When I do my very, do I just need to do it for new circuits added, or do I need to list all circuits on the very even though I’m only adding new one? .
Electrical2Go - Online Electrical Supplier
Aico 3000
SparkyAndGeorge
Electrical Installation Certificate. All circuits.
buzzlightyear
buzzlightyear
on the test cert each circuit the you are doing ,say 3 then circuit 3 you are doing .
M
Martin Kerr
On your electrical installation cert ,you can mark all the existing circuits ,circuit not tested and only detail the new circuit
But you would need to update the circuit chart or identify the circuit on the Db
Sean McD
  • #6
Makes sense just documenting installed circuits. I’ll just list them on test sheet etc.
buzzlightyear
buzzlightyear
on the description and extent , put what work carried out.
and put testing of the circuit .
ackbarthestar
ackbarthestar
Mentor
Don't forget to state that you have checked that the maximum demand hasn't been exceeded., Earthing and bonding are in place, as appropriate.
Pete999
Pete999
Check bonding is in and OK, is there an RCD
in situ
davesparks
davesparks
Mentor
No need to list all of the circuits not worked on, that could result in a ridiculously big certificate just fir s couple of new circuits.
PEG
PEG
Mentor
Also,depending on set-up,ensure you do any testing or inspecting,which prevents issues on those existing circuits,impacting upon the addition(s).
You can mitigate to some extent,with your terms paperwork,but that will not stop the phone ringing...
Scolmore Electrical Products
Reply to Documenting new circuits in existing board in the Electrical Forum area at ElectriciansForums.net
Top Bottom
