- Reaction score
- 16,960
Builder,
Say no more
Builder,
what's wrong with BG? never had any problems with loads of BG kit since the issue with tight screws being backed off and secured with loctite.That is terrible …...
I mean who in their right mind would install BG
By far and away 1st prize in the "Not having a effig clue" awards 2019.View attachment 50637
Just opened up this CU on a garage conversion.
Sweet Jesus.
Whole thing wired in 1mm 3 core.
Into a b50.
Supplies sockets and a utility room...
More later.
The scary thing is , I have seen far far worse in peoples houses
Not calling you a liar but you'd have to try pretty hard to do worse than that.
I have seen worse where the tenant had used cat5 for basement lighting fed from a B50 mcb for some led fittings!
I've tried three times to write an appropriate comment but words are letting me down. You'll have to invent some colourful new vocabulary for your report... I don't think standard English is up to the job.
E2A sorry I can't stand the suspense. You have to tell us what the polarity of the 'submain' is, what with the brown wires all being connected to the case and that. Pleeeease say it's the neutral or show us the other end.
Not entirely sure that the chimp that installed it did either?!I have no idea how that even works??
That there is a total abortion, @Marcus Vaughan
I can’t see one regulation that HAS been adhered to.
The gray sheath is inside the enclosure though
