I like how the tails are going in through separate glands on a metal enclosure . Have the ever heard of eddie current lol.
Any issues with this.........
Commercial install - Livingston West Lothian Scotland.
I was there doing Underfloor heating existing spur - had a quick look in board - no idea how recent this install was or who did it.
informed client (heating engineer) guarantee nothings been done by building owners.
View attachment 33609[/QUOTE
That's been shown as an insignificant problem with the currents involved in a domestic situation.
There's a Youtube film knocking about somewhere.
Lol. I've seen less fooked prostitutes!Which bit of gaffer did you stick the pass label on? I can't see it at this angle! That thing is obviously loved
It's always nice to see a bit of MI.
I stuck a board in last month, it was only a basic one in a detached garage but I still took the same care as I would anything else. Feel free to criticise!
That's a disgusting install. What really gets on my ---- is at work we loose out on jobs because we are more expensive than the idckheads that throw this **** in. How lazy, preloaded board, just shove it on the wall as is and stick the wires where you need them, no care, no attention to detail. That's ignoring the madness at the supply end.
Our prices are quite a bit higher than most of the local electrical companies, partly because there is a number of us as well as office staff, but I hope we offer value for money. It is sometimes difficult to compete with the huge number of local one-man-bands, some of which seem to get away with poor and non-compliant work, but we have enough work to keep us busy.Be careful posting pic's like this, it may give a few a reality check of how to make a job look professional and done with pride, if the average joe homeowner see's this then they will all expect this level and most sadly to say won't get anything near to it. :mamazed:
It is written on the conductor attached to the banjo. The CPC is wrapped in G/Y tape as I ran out of sleeving large enough to fit.Very Nice.
Just wondering....
Does that say armour on the sleeving of that cpc?
There is a gland and the banjo is on the outside of the enclosure, connected with brass nut and bolt, outside so all brass in contact, better than a possibly rusty steel locknut in contact with the banjo.How have you attached to armouring, is there a banjo on the outside of the enclosure?
It's not in the neutral bar it is in the neutral terminal on the RCBO. It is hidden behind the line conductors.Also, where is the 2nd neutral for circuit 2 - cant see it in the bar or is it just hidden behind?
Yes, the neutral flyleads from the RCBOs are in ferrules. I have used them as I shortened them to save space in the enclosure, which of course involves cutting off the manufacturers ferrule. Fine and very fine stranded conductors must be fitted with a ferrule unless the terminal is specifically designed to accept such a conductor, the flyleads are very fine stranded so ferrules must be used.Are the neutrals in ferrules? if so why have you used them? Aesthetics?
The neutral flyleads from the RCBOs are all the same size, the circuits neutral is connected to the RCBO it's 1.0mm, no joints in the consumer unit.The neutral for circuit 4 looks larger than the live? in fact they all look the same size, is there a joint somewhere behind the breakers?
It's 40A (CGD don't do a 45A for some reason) for an instantaneous undersink water heater.What is the 45A breaker supplying?, is it a hot tub or something?
Thanks for the comments!Not being critical at all - nice work, obviously some care and attention to detail
Cheers
Andy
