I tidied it up a bit with what I had in my bag, but need to return to gland the top left cable which is the incoming supply. Actually, it needs to be replaced as the current cable is black rubber sheath with rubber insulation on the cores, and the wires are fine stranded silver coloured which when scraped, do not reveal copper underneath, so I guess a new length of cable is the way forward.
and before anyone shouts at me, I know the blues in the bottom Wago should have been trimmed further...
That's a lot better than how it was!
The only thing I was thinking is that the nut on the earth stud is tightened on to plastic.
DPG, I can see what you mean, however the earth stud protrudes into the box through a hole drilled in the back. The stud is bolted to the metal casing, then there is a second nut on top, which protrudes even further into the box.
Ah I've just looked closer. I didn't realise you made a clearance hole in the enclosure. I thought the nut was clamping down on it.
Maybe some warnings?
Safety earth do not remove...
Caution, This installation has wiring colours two two versions....
Warning, multiple supplies....
Warning, this installation should be periodically tested....
This installation or part of it is protected by a device which automatically switches off...
This installation or part of it is protected by a surge protection device, which should be periodically....
Warning, may contain nuts...
Warning, stairs may go down as well as up...
Just the normal plethora of labels that have to be added...
davesparks and julie,
I intend to fit gland on incomer, for cable restraint ,but waiting til I fit new cable/
Sadly it's Men's Shed Charity and has had to close due to the coronavirus, which is a bummer.
However...
and today I have worked out how to print these labels onto standard Avery sheets!
YAY!
[automerge]1584394267[/automerge]
baddegg and static...I'm working on it!
Joking aside that flex would probably pull 26a without too much trouble
I have seen an old JW video showing 1mm/1.5mm solid taking about 50a before it started to bubble and smoke
However...
YAY!
A pointless label, and it's wonky
