- Reaction score
- 25,464
Which screw the one with the earth on it?Who drilled and tapped that set screw into the solder?
Yeah, it's on the banjo, I know...but it does look like it screws into the solder..Which screw the one with the earth on it?
It is a banjo a strange set-up but it is rock solid. Look lower down there is the original braid.Yeah, it's on the banjo, I know...but it does look like it screws into the solder..
It’s a good job I’m only 6ft and 15st. Otherwise it would have been a really really tight squeeze to sort it. Instead of just the really tight squeeze it was!So they over clad the original ceiling by the looks , I often find those big transfomers feeding a bunch of 12v spot lights wired like that using twin flex and connector block
The issue is often getting to the transformer which is often inaccessible without mashing a hole somehwere
I used plenty of cable lube.I’m 6’, and there’s no way I’d be fitting in there without taking most of the ceiling down….
I didn’t lick it this time as hadn’t long since had lunch, so should be ok…Hope that Artex did not contain Asbestos.
I always wear a mask when in lofts. 99% of the time around my way they all seem to have the old fibreglass in which gets everywhere.All very well being flippant about it, but that ceiling coated in Artex had been Drilled, punctured and cut and could have released fibres into the loft space, I hope at the minimum you wore a mask when in the loft.
And accessible.Still, did avoid lifting many floorboards, so I can see the advantages of the system, if fully labelled!
