Can think how I got on before they were inventedThank God for the Multi-Tool
I have to confess, I do this (sleeved brown) for the occasional PIR where the cable's run externally.
I actually have 20meters of so of H07RNF in 4 core that I bought for this reason, but the smallest I could get is 1.5mm, and it's thicker than armoured. You just can't get it into most PIRs.
Well that's scuppered my little game hasn't it
4 c and 5 c hi-tuff is no thicker than standard 1.5 3c flexCYKY that many wholesalers sell as Hi-Tuff would be much less bulky.
NYY-J / Hi-tuff stuff is another option and probably easier to find than Flexishield (as long as you are happy with black), but still on the thick side and I can't recall seeing 1mm versions of it.CYKY that many wholesalers sell as Hi-Tuff would be much less bulky.
NYY-J and Flexishield are fairly nice to work with as they stay neatly in place with moderate fixings, where as the rubber stuff flexes a lot, which of course be useful in some case.
Hope you stuck a RCD 'test' label on the wall above the worktop, directly above it.no way don’t say someone’s put another consumer unit behind them units to supply the hob! No access at all
had to cut a big access panel in the side of the new drawer unit and found it
What are peoples opinions on using FP200 outside ?
use white and the sheath will be dust on the ground within 2 years.What are peoples opinions on using FP200 outside ?
I remember doing this when we used to work for the solihull councill in the 2000s , with a robin tester!!My own dodgy pic. Been testing an empty school with a non time delayed 100ma main switch rcd on TT. It was being a right royal pain in the --- so I took it out of the equation, safe me thinks so.View attachment 100878
Well yes I was using a Robin tester but that wasn't the sole reason. It was preventing testing of the 30ma rcbos.I remember doing this when we used to work for the solihull councill in the 2000s , with a robin tester!!
Never use an mft they are far too temperamental.I miss my set of Robin testers, so much faster than MFTs!
mine isn't and it's 14 years old. never skipped a beat.Never use an mft they are far too temperamental.
