- Reaction score
- 16,644
Beaten to it quicker than a tripping RCD.
Ooh I like that phrase. I'll remember that one.
Come to think of it my Mrs mentioned something similar when we were in bed the other night.....
Yeah the tw@t lol. Fastest finger first.
You're on top form tonight !
10.5kw shower, 45a switch, 6mm T&E and a 63a MCB as the OCPD with no RCD. This is the result....
But at least they lined it up with the light switch.
View attachment 106664View attachment 106665
I still have a load of "SafePlates" in a box somewhere....Notching the joints was the plumbers way, and I think electricians back then followed suit, and probably still do to a certain degree, as sometimes needs must.
Brings back memories though of live nails poking out the floor, or the missus shouting up the stairs that there's water dripping from the ceiling.
If that wiring was staying, I would notch some nail plates into the floor board, better than having to junction box the cables just to divert them through some joist weakening holes.
It looks like a 'Click' switch which are normally pretty good , probably just badly terminated. I hate those 10kW + showers, ridiculous amount of current draw really.10.5kw shower, 45a switch, 6mm T&E and a 63a MCB as the OCPD with no RCD. This is the result....
And, yet again, its the neutral connection that failed. Funny that.It looks like a 'Click' switch which are normally pretty good , probably just badly terminated. I hate those 10kW + showers, ridiculous amount of current draw really.
I never had a problem with 50 amp Crabtree pull cords, double terminal screws helps.I think some cowboys/ plumbers fitting showers think as long as the live is tight, it’s all good. Neutral isn’t that important, is it??
Always seems to be neutrals… with pull cords as well. And it happens with 7kW as well, but doesn’t make as big a bang as a 10
Wait until everyone’s EV charge points start melting… oh wait, I’ve already had one!
Should have tightened that neutral another half turn.I think some cowboys/ plumbers fitting showers think as long as the live is tight, it’s all good. Neutral isn’t that important, is it??
Must admit when I first started out on this rocky road I was surprised how much more torque I could get with the correct terminal screwdriver with approximately the same amount of effort.
