- Reaction score
- 17,014
I screenshot a phone photo, then crop out the extra screen… reduces the picture enough to be under the size limit.Ahh photo too large for the server to process.
Or crop the original.??
You can use an image compressor such as Easily compress images at optimal quality in seconds. - https://www.iloveimg.com/compress-imageWas it the wasps or the mice that eat the phone cable?
Probably a lathe and plaster wall. I've used every screw hole available on many occasions, plus a bit of adhesive on the back.Making sure….respect to the sparks who went the extra mile!
Exactly this - only two of them were actually doing anything. This house has a mixture of L+P, L+P with plasterboard on top, and in one case L+P ceiling with OSB board and then ceiling-board which made fishing delightful fun...Probably a lathe and plaster wall. I've used every screw hole available on many occasions, plus a bit of adhesive on the back.
I absolutely hate lath & plaster.Probably a lathe and plaster wall. I've used every screw hole available on many occasions, plus a bit of adhesive on the back.
Is it upside down or not?Making sure….respect to the sparks who went the extra mile!
YesIs it upside down or not?
No it's not cos the MK logo and list no. are the right way up.
Ahh but to what did I say yesNo it's not cos the MK logo and list no. are the right way up.
And maybe a MF enclosure, you do get some lovely work thoughCall out today as a light switch kept tripping the MCB of the circuit. So after finishing another job I called in on my way home.
I'm surmising that some hamfisted clod has knocked a nail or screw through the cable and it's failed over time. 2 of the 3 conductors had a short when IR testing.
Replaced the 2gang switch then had to go old school to pull a new piece of 3C&E through to make a temp fix. Told them they need to find where the leak is in the property and stop that before I do anything else. The back box has almost disintegrated and the wall and ceiling are damp to touch. So will be back to fit new capping and back box once they have sorted that out.
View attachment 107162View attachment 107160View attachment 107159View attachment 107161
The MF enclosure is what I put in when I pulled the new bit of cable through.And maybe a MF enclosure, you do get some lovely work though
The wago light box isn't mf though just sayingThe MF enclosure is what I put in when I pulled the new bit of cable through.
The wago light isn't mf ?
With the amount of water/damp they could do with a gel boxAh, I misinterpreted what you meant. Yes I know it's not a permanent solution. They may have to replace the ceiling plasterboard so I am waiting to see what happens as I may just run a new complete section of cable.
