Discuss Does a 13A plug in oven need to be wired into a cooker switch in rental properties ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As far as i know, in Scotland anyway, there is no such requirement. If the manufacturers fit a plug and say it's to be plugged in, that's the way to go.
Indeed, for non-electrically minded landlords who have a hands-on approach, many prefer the plug-in option for all appliances, such as cookers,hobs,washing machine, dishwasher etc as it makes swapping out a faulty appliance quick and easy with less hassle for landlord and tenant alike. It makes ISITEE simpler too.
would not be appropriate for anchors.you'd lose so many you'd be adrift on a lee shore. every pirate's nightmare.
Certainly not appropriate for anchors, Tel! Plug-in anchor and chain is bound to fail, so I always make off the bitter end into a SFCU. This is not only more resistant to "pull" than a plug in a socket, but it means that as the anchor chain goes over a metal roller in the bow, and the forestay is connected to the roller housing, then in an electrical storm, if lightning strikes the rigging, it is diverted to the sea, shivering, but not charring, my timbers...
As for Lee Shore? Indeed, every seagoing man's nightmare...I should know...I went out with her once, in Portsmouth!
If you cut the plug off some appliances it voids the warranty.
Does it? Care to back this up with some facts or are you just going on hearsay and what the manufacturers have to say in the subject?
As far as the law is concerned then cutting the plug off only voids any warranty claim directly relating to the plug, not the rest of the appliance.
Very true, Marconi! I have changed ovens after 6 month lets because they are so filthy I couldn't contemplate a professional oven-cleaner person wanting to deal with it.
What DO they cook in there? I clean mine once a month, or so, and it always looks like new.
BTW, what do you all use to clean the acres of stainless steel in a kitchen? Fridge-freezers, ovens, extractor fans...I tried everyting from commercial stuff to old wives' remedies...and actually a professional cleaner pointed me at the perfect solution...but i want to hear everyone's views before revealing the miracle cure!
If it comes supplied with a plug, plug it in.
if it comes without one, have a spark wire it in.
why do people have to complicate matters and quote laws that don't exist anywhere other than in their own minds??
Cheers Pirate
All, thanks very much for taking the time to reply and sharing your knowledge and experience.
In summary :
  • There are no additional electrical or building regs for a rental property for this situation
  • If it's got a plug, use it.
  • If you need to add a new spur it'll need RCD protection
  • If you hard wire into a new SFCU, need to consider whether the cables warrant RCD protection
    • ....I might ask my scheme for their view on that one rather than stretch this thread
  • And finally, in all situations, beware of bullshitters !
WD40 makes a pretty good stainless steel cleaner and polish
Why do people insist on perpetuating this myth
It does not void the warranty what it does do is prevent the appliance engineer carrying out safe isolation of the appliance to carry out repairs if it is hard wired.
They are trained that safe isolation is to pull the plug end of no other method of safe isolation is available to them and they will refuse to repair unless someone else will disconnect the appliance that is not voiding the warranty it is the procedure they are trained to follow
lettings agents , the great rip off of our time, what do they actually do ? what knowledege do they have ? here they are quoting regs that don't even exist, driving about in new minis with logo's on doors. Hey ho rant over :mad:
Reply to Does a 13A plug in oven need to be wired into a cooker switch in rental properties ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hi all, I'm new on here.... I have an existing 32A cooker circuit with a wall switch with 13A plug hole.The manufacturer says the new oven is...
6K
