Discuss Does any old wiring contain asbestos? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, not an electrician by any means & know very little about it, hence why I’m asking for help if possible.
Came across lots of old/dead wiring on a property recently and was wondering if it could possibly contain any form of asbestos? Was this something that was commonly used in wiring in the uk? I’ll try and attach a pic.
Any help would be greatly appreciated
I wouldn't expect wiring to contain asbestos but old fuses and main switches often do. The biggest risk from asbestos is where it is used as thermal insulation or as a filler in artex.
Hi,pictures are not too detailed...looks like rubber covered,not usually containing any dangerous materials,but don't be licking it ;)
Asbestos was not generally used in cables for the wiring installed a building and the cable in your pics, which looks like TRS, does not contain it. Only inside high temperature appliances like cookers was the cost justified, and even those were often non-asbestos from the 1960s. It is most likely to be present in fuse boxes etc. pre 1960, as flash pads and gaskets.
Reply to Does any old wiring contain asbestos? in the UK Electrical Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi I’ve recently got my first home I’m not entirely sure when they were built I’m thinking possibly 60s or 70s? My problem is the storage heaters...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
First time DIY post here…. My wife and I bought an old, run down 70’s lake trailer and ran into an AC wiring issue. Our thermostat is wired...
I’m looking to add a new light and with a switch to a old property with older wiring techniques I have not come across. From looking the cables...
