Discuss Does anyone know of a cable identification guide? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
bleach
Just wondered if there is a guide out there to identify csa of cable by visual inspection? I have read about confusion re tails eg 16mm or 25mm. or twin and earth etc?
Obviously some have markings on, but you just get to know with experience. If your struggling I have seen a few of the younger guys with some cut off in their tool bags marked up with the sizes on them to use a reference.
easy quick way i used many moons ago was a piece of plastic with different sized holes drilled in it.
A digital vernier calliper works well, it can easily tell the difference between 1.0mm and 1.5mm and I've used mine to identify the size of imperial stranded T&E cables, which I am less familiar with.
Just use the offcuts reference method. Who the hell carries around a digital vernier calliper with them and a scientific calculator?!
Reply to Does anyone know of a cable identification guide? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Does anyone know what the cable in the picture is called? Or anything about it? Labelling on the outside is “E SPC Electric Cable 600/1000v” Its...
Hi all, My question relates to the omission of overcurrent protection (specifically overload and fault protection) at the origin of an...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi everyone, i might be having to run new meter tails from meter box to consumer unit which is just under 3m run, i have used 25mm 3 core before...
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
