Discuss Does anyone know what this is? in the UK Electrical Forum area at ElectriciansForums.net
Thank you. Just got scared when we seen the other side of otIt looks like a switches fuse outlet for maybe a panel heater before the wet radiators were put in.it might be worth getting an electrician in to have a look and either remove them safely, disconnecting them from any supply, or changing the faceplate to a socket and moving it slightly so it can be used.
Fools seldom differ.Great minds think alike, Tel
and so do we
Then it’s worth getting it looked at. Maybe at one time it was 2 heaters back to back... It looks like there has been a switch on that side of the wall as well.Thank you. Just got scared when we seen the other side of ot
If it was still there and hidden behind the pipe... just use a Birmingham screwdriver..At least the screw behind the pipe is missing so the plate can easily be removed from the box!
Reply to Does anyone know what this is? in the UK Electrical Forum area at ElectriciansForums.net
