Discuss Does anyone know where i could get a led strip light set up that is powered by a force sensitive resistor/weight sensor? in the UK Electrical Forum area at ElectriciansForums.net
Ultimately for my project im making a lamp which will be powered by the weight of an object. So i want to power the whole led strip lighting solely through placing an object on the weight sensor pad. If anyone knows where i could buy a setup like this or how i could go about making it myself that would be great :)
Hi - to generate meaningful electricity you are going to need motion, not just a force. You could use a weight on a string over a pulley to turn a shaft, but it will stop when the weight hits the ground. Gravity from the Moon can be used to generate power in the form of tidal generators and gravity from the Earth is used in hydroelecricity.
.....powered by the weight of an object. So i want to power the whole led strip lighting solely through placing an object on the weight sensor pad....
You mean you want the weight of the object to actually generate power to run the lights or you want the weight of an object to operate some type of switch which connects power from a plug-in power supply to the lights?
Pressure mat similar to alarm system ones maybe. How heavy is the object? If it's very light you may need to be looking at a strain gauge with amplifier circuit which then switches a power transistor/relay whatever.
Reply to Does anyone know where i could get a led strip light set up that is powered by a force sensitive resistor/weight sensor? in the UK Electrical Forum area at ElectriciansForums.net
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Next week I'm starting to build a few built-in wardrobes for the bedrooms and I've hit a brick wall on the lightning element. Normally I run 1.5mm...
I just installed some 24V LED Lighting Strips single colour in my kitchen and it seems at every point where I added a quick connector that...
I’m in the process of creating a jewelry box in solid oak, where the lid of the box acts as a mirror. I’m exploring the possibility of adding LED...
My view on life, in any field, is not to produce more but to consume less. Everybody told me this is a very eccentric weird mentality. Perhaps...
