Ducksy
Require the circuit to be re-tested?
I'm having a dispute with a colleague about a electric shower install.
I could swear I remember a Reg stating if the load (Ib) is changed on a circuit then it needs re-testing (at least I would have thought a MWC regardless if the kW is higher or lower).
I know people are going to say what about adding or taking away a spotlight, and yes that's a good point But surly it's different for higher current equipment.
Basically I think unless you change the unit like for like ie same kW rating then a MWC should be issued. But can someone point me to a reg that backs that up statement.
Many thanks.
Many thanks.
