Discuss Does Tesla Power Wall receive DC from the panels? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi,
Does the Tesla Power Wall receive DC from the solar panels?
Or does the solar panels' DC get converter to AC by an inverter on the roof, and then the AC goes to the Tesla Power Wall?
It would be quicker for you to research the answers to some of your questions, by typing a lot fewer characters into your browser/ search engine, and reading the answer!
e.g https://www.tesla.com/sites/default/files/pdfs/powerwall/Powerwall 2_AC_Datasheet_en_GB.pdf
Thanks, its strange that the Tesla power wall insists on the customer buying their own solar inverter, because this means that the customer then has to know how to spec that up.
The attached pic shows the solar inverter being right by the Tesla Power wall...which means the DC current of some 80A getting brought all the way down from the roof, to the consumer unit...seems very odd?
They seem to offer different options for the US market (possibly also Australia), with inverters being included dependant upon application.
It's not something I know much about, but would suggest reading information aimed at different markets to gain an understanding of what they offer in different regions.
Tesla designed their battery to be system agnostic, it can work with any inverter (or none, as just a quasi-UPS). If Tesla supplies an inverter, it becomes their problem.
Very unlikely to be 80A coming down. 360W solar panels in a series string usually have a max current of <10A, so even two parallel strings will only send 20A of DC to the inverter.
Reply to Does Tesla Power Wall receive DC from the panels? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi all - relatively new to Solar but I’m looking for opinions on fitting DC SPDs on a TNCS installation. Are we just earthing the SPD from the...
Hi all, I've installed a Tesla Gen 3 wall charger supplied by my client. For your information, the place that I installed is in a block of flat...
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
