Discuss Domestic Isolation ? in the Australia area at ElectriciansForums.net
R
Richard3009
If I use a henley block and a set of tails to feed a new consumer unit on an existing installation adjacent to an old board, do I need a point of isolation between the henley and the new board, and would a recomendation be made to upgrade the exisiting re-wirable fuse board.
The regs do require a single point of isolation for the installation, however this is open to interpretation as many see the main supplier cut out as the isolation point.
Why not just upgrade the existing board and put new circuits in there?
Reply to Domestic Isolation ? in the Australia area at ElectriciansForums.net
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Evening, I've been asked to install a supply to a sprinkler system in a new installation that must be separate to the building electrical...
Was helping a friend out and changing their CU which had a date stamp from 1990. Good quality Merlin-Gerin unit and a nice job originally. They...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
