- Reaction score
- 644
Not much to do with this lockdown going on.
So friend of a friend wants a Little job done; light in toilet area swapped with a sensor
light.
Shows me where it’s switched from in the hall a 2g switch ,the other switch does a light in the hall too.
Ok,there’s are one cable @ the toilet light,so fits sensor light,& decides to connect the switch wire & feed together,@ the switch ,so there’s a 230v permanent supply.
At the 2g switch there’s only that cable,no cable on other side of switch,so it’s definitely wasn’t a 2g switch.
Gets a call later the lights are not working,can you sort it.
Gets to the house about 6.00pm, & he’s showing me what should happen,the 2g switch doesn’t do anything & the hall light is on constantly.
Ive told him the switch was never a 2g anyway,argues & argues.
So I put everything back as it was the switch now operates the hall &toilet light.I may have to go back & sort him & the light out.
How much shall I charge
light.
