A
Aok1
Would a door entry system be exempt from RCD protection?
The system is on a residential upstairs flat and the guy is quite ill. The CU has a rcd for the sockets but the lights are on the unproteced side of the board.
There is a spare way on the unprotected side i can use? Would i be ok not to put this on a rcd side?
My concern is that if anything tripped, the fuseboard is downstairs and if he needed medical attention he may not be able to open the door if it was on the protected side. (worst case scenario)
