Discuss Double feed? in the UK Electrical Forum area at ElectriciansForums.net
I understand that but the smoke alarms are on there own breaker and the last smoke alarm feeds into lighting so if I’m right when lighting breaker is off it could still be live because of smoke alarm feed??It is quite common to feed smoke alarms from the lighting circuit.
They are fixed low-current devices and the advantage is if the circuit trips folk the to get it fixed so they are not in the dark, whereas a dedicated smoke alarm circuit is not always checked for operations.
It’s looks like they have just crossed over with cable from lighting junction box and gone into the smoke alarm which is already fed??OK I had not clocked the fact they are linking two circuits. That is a definite no-no!
If that is the case it is clearly a mistake.
[automerge]1593632983[/automerge]
Have you checked if they are linking circuits? It might be the smoke alarm MCB feeds all other but not that one for some reason (difficulty in wiring, lazy, etc, etc)
Did you not test it to verify/carry out safe isolation.I understand that but the smoke alarms are on there own breaker and the last smoke alarm feeds into lighting so if I’m right when lighting breaker is off it could still be live because of smoke alarm feed??
Unable to access property 10 minutes after finding problem, will test tomorrowDid you not test it to verify/carry out safe isolation.
report back to us nosy sods what you find.Unable to access property 10 minutes after finding problem, will test tomorrow
[automerge]1593633921[/automerge]
Thanks all
Will do ?report back to us nosy sods what you find.
Ideally with pictures... we love a good picture ! (not all blurry with the fun bits half cropped out)report back to us nosy sods what you find.
Reply to Double feed? in the UK Electrical Forum area at ElectriciansForums.net
