Discuss Double plug socket not working... in the UK Electrical Forum area at ElectriciansForums.net
dates back to when smoke packets had decent foil. complying to regs.
Hi all,
I woke up this morning to find a double plug socket in the kitchen is not working at all however every other plug in the house is fine, and nothing has tripped etc...
I have turned of the mains to the whole house and check behind the plug for anything obvious and all seems fine, no lose wires etc.....
I was thinking to replace the face of the socket next? I assume this is fine to do (like for like)
The fact you even asked this question has set off the alarm bells, gasp and double gasp
I don't think he's a Sparky
[/QUOTE]
Oh like most of the forum then
Reply to Double plug socket not working... in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Have a single plug socket which has been working fine for years. It is behind a unit so nothing has hit it. I looked at the socket and can seen no...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
