Discuss Double Trouble in the The Welcome Forum area at ElectriciansForums.net
EddieB
Whilst replacing an old DB I found that an outside light had been wired in and doubled up at the MCB, foolishly I had counted the the old fuses without taking the cover off, the new DB I had bought allowed for no more expansion can I double up at the MCB with this extra light, rings circuits I know is a no goer for an additional socket to be added due to the rating of the MCB (32a) but can I double up on a lighting circuit.:confused:
Welcome!
What happens if the customer wants additional installs in the future and no spare ways?
Not good practice to double up and it doesn't comply, I would just exchange the CU for one with more ways plus expansion.
Warren G
Thanks for the prompt reply Let's assume I cannot change it, I know it aint good practise but what doesn't it comply to? is there a regulation that stipulates you cannot do it.
Hi mate,
Take a look at Big Red - 314 Division of Installation (314.4) in particular.
Sorry Mr G gotta disagree with ya there!
Doubling up on an MCB is no different from teeing off of a rose somewhere!
As long as ALL the lighting is not on one MCB if there are just 2 circuits then no prob!
Same with RFC and spurring off 32A MCB. No Different than a spur from a socket outlet.
Very logical point Jas, think your right on that! :eek:
Had a dig around and found thats its a question / answer that is published in the NICEIC technical helpline book 'From the phoneline'....
Question There are no spare ways in the DB for my new lighting circuit can i use a existing one?
Answer YES although Reg 314.4 requires each final circuit to be connected to a seperate way in a bistribution board, a circuit may have more than one "branch" connected to the appropriate way.
nice one! ;)
Thanks boys
It's good to Talk
There you go mate, thanks what the forums all about. A logical answer. ;)
Reply to Double Trouble in the The Welcome Forum area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Howdy, I'm looking for help with my plan to install an extra internal double socket and an external double waterproof socket to my garage. I...
Hi, Need some help with an odd setup. I have a large room with many lights that i separated into 2 sets. In Box 1 there is the 14/2 power in, 2...
